how to recover the lilo bootloader?
dragonwell
Junior Member level 3
restore lilo bootloader
hi all,
i used to install suse8.2 in another patition rather than c drive & set the bootloader to msb. however, i reinstalled winxp some days ago & it overwrote the msb so i cannot log into linux anymore. Could anyone help me how to reinstall the bootloader instead of reinstall suse.
i forgot to make a bootdisk :(
thanks in advance!
dragonwell
use loadlin to boot the linux,then restore lilo:)
Hope it help you !
first,you should boot your linux.
loadlin root=/dev/hdb4(the root patition of your linux)
after that, you can easyly restore your lilo setting by
the fllowing command
lilo -v
already fixed. Thank you!
