eigenroot
Junior Member level 3
I am trying to measure low-frequency noise such as 1/f noise spectrum from a material.
I saw some people applied a DC current source, took the voltage across the material and amplified it with a preamp before it went into a FFT spectrum analyzer.
But the problem is the noise is relatively small compared to the DC component, and the amplifier can easily get overloaded by the DC offset before amplifying the noise to a reasonable level. But if I use a DC block, the low cut-off frequency is still not low enough. For 1/f noise, I would like to measure down to 1 Hz. Can anyone suggest a way of doing it? Thanks.
