How to interface RS232 with PIC16F877?
ryusgnal
Malaysia
smainj serial
How to send and receive data from RS232 to PIC16F877? Is there any suggestion for the circuit and sourcecode?
smainj.free
go to this site
you can get some real useful 5 vedios
that will help you
use rs232 for pic16f877
sai001 said:
go to this site
that will help you
What kind of software is used in the tutorial? where i can find it?
smainj pcb
ryusgnal,
I have something writen at Borland C++Builder 5.03.
If you want, I may post it here, or send to you.
smainj.free.fr
andre_teprom said:
ryusgnal,
Can you post it here. may be it will help me or other people.
Thanks so much!! :D
smainj
ok...attached, but, some comments in portuguese language :D
    ryusgnal
download interfacing rs232 to pic16f877
You can use Visual Basic 6.0 to make GIU interface which is very simple. Firmware can be done by using USART module in PIC16F877. Good luck.
rs232 with pic16f877
How about the C program for RS232 with PIC18F4550?
interface rs232 to pic16f877
ryusgnal said:
sai001 said:
go to this site
that will help you
you can use the UART rx/tx of pic16f877.
check the pic16f877 datasheet, where you find out the pins of UART...
The best and easy software is the c language for PIC microcontroller, CCS C PIC, or HITECH.
For PC, the visual basic is the best and easy way to comunicate with PIC16F877.
GOOD luckl
@ryusgnal
vISUAL c++ is for PC... you need one compiler for a uC.
vsmGuy said:
@ryusgnal
I mean instead of using VB for interface. I prefer to use visual c++ because I'm not very good in VB and nobody can guide me in VB.
you should know about 9 pin and 25 pin RS 232 data traveler serial port data sheet
so download it and try to program in VB.net
I think you should check Microchip website. It is a general question.
Use a solderless breadboard or a pcb from Olimex.com. You will need a 16F877A , St232A and a power source. For the power source you could add your own with a 7805 regulator and a wart. Check Futurlec.com or mouser.com for parts and datasheet downloads. Connect the st232A output/inputs to the RX and TX pins on the 16F877A. Download the ST232A datasheet from mouser or www.stm.com
Next goto Oshonsoft.com and download the Pic-Simulator which includes a basic compiler. It also has a PC com port interface to talk to the 16F877A. You could also use any number of terminal emulators available on the internet. Use Google.
If you're willing to spend some money buy a PicKit2 from Microchip ($40.) and the Pic-Simulator (29 euro). If you want to make life very simple also use the bootloader on the Oshonsoft site. See projects.
use the inbuilt function
#use RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7)
output_c (0x40); //RC6/TX RS232 =1
SET_TRIS_c(0x98);
easy & fast
