dumindu89
Member level 1
According to the datasheet of MAX2606, Absolute maximum rating for OUT+, OUT- to GND -0.3V to (Vcc+0.6V). And Vout (p-p) (differential) = 2x1mA[(1kΩxRload)/(1kΩ+Rload) I implemented the following circuit (both C2 and C3 are 2.2nF and other values are same as in the diagram) and get the single ended output and measured using the oscilloscope. **broken link removed** Unfortunately the output peak to peak voltage is just 300mV. (Vcc = 4.5V) Why I can't get at output peak to peak voltage least up to 1/2Vcc ? Please help me, I want to input the output of this to a 74F14 schmmit trigger IC. Any suggestions please?
