How to determine the input impedance of a patch antenna using ADS?
MrElec
Tunisia
Hello,
I want to determine the input impedance of a patch antenna (10.8cm * 10.8cm) by using ADS Momentum,how can i achieve this?
How can i find the co-polarisation angle and upon which criteria?
thanks.
Re: Patch antenna
Are you referring to Radiation resistance? I attached my template for you to verify.
Goodluck...
    MrElec
Patch antenna
hi,
You can find everything about Rectangular Microstrip antenna in the book names :
Modern Antenna Design, Thomas A. Milligan, 2nd Edit, John Willey & Sons, 2005.
It'll tell you how to determine feed positition and calculate respective input impedance.
Regards!
    MrElec
