How to break 8051 lock and read the hex file from the IC ?
sunish
8051 lock breacking
hai all
after downloading the program to the 8051 based microcontroller,we used to lock the ic with the help of the programmer sofrware.is it possible for anyone to break this code and read the hex file from the ic?.
sunish
Re: 8051 lock breacking
It should not be possible to do that, not by "normal" means, anyway.
Once the code protection bits have been programmed, the user has no way of reading out the contents of the on-chip program memory.
It depends on how bad the attacker wants to read the chip. I have seen some research slides whrere the attecker dissoslves the plastic chip package with an acid that dissolves the package but does no harm to the silicone chip. Then the chips memory is covered with UV resitant material and the protection fuse left uncovered. When exposed to UV light the protection fuse is cleared.
If you would like to read more on this issue goto:
Regards,
IanP
CODE BREAKING IS BAD AND BECAUSE OF CMOS PROPERITY CODE CAN BE BREAKED.
hai
i think that it's bad to break the code of the program of someone else.but we should be aware of the technique they are using to break.so that we can work out some alternative solutions to protest our program
sunish
8051 lock breacking
Yes it is possible. I have seen one advert. in magazine for the same. After that advert. the magazine got lot of angry emails from developer.
Re: 8051 ic lock software.
hai all
how to lock 8051 ic.
Please give me any suggestions.
Yekambar N
Using a programmer program the security bits (lock fuses) ..
IanP
:wink:
hai all how to lock 8051 ic. Please give me any suggestions. Thanks Yekambar N
As a memeber, you are free to open a new thread of your own querry. You have re-opened a 2006 thread again.:grin::grin::roll:
hai
sunish
did anyone break your or anyone other's code, with existing locking tech in microcntrollers????
