freeman3020
MPPT implementation ,how to balance
Hi
I searched a lot for solar MPPT , I know that system search for optimal point of voltage and current to got most power of Panel
I have confused that how to balance duty cycle between MPPT and battery voltage
if we used duty cycle to adjust output voltage from buck converter then we will neglect searching for MPPT , and if we find MPPT how to set output voltage from feedback?
let say if I set duty cycle with load on panel and got MPPT ? how to determine and adjust output voltage, if we adjust voltage let say 14 volt then solar panel not will be in optimal value??
:shock::shock::shock:
Hi
