incol
Full Member level 2
The 2mV input signal is two small compare to the offset or noise voltage. So which amplifier can be used to amplify so small signal? The input signal can be DC or AC. Could anyone help me? thanks
for amplifying , use the NON INVERTING AMP, Select the gain to 50, to achieve this mark. But it must be taken care that , if the 2mV signal is induced with noises, then the same will also get amplified, so better to use a filter along with that. With the same Opamp, you can a make an active filter.
Did you read post #2?
It gives the correct solution to your general question.
If you give more specification about
* expected errors
* frequency
* power supply
* and so on
...we can give a more detailed answer.
do you have some document about the OP07's architecture
