How does the circuit work ?
shalky
Newbie level 6
This is a part of a circuit, the work frequence is 125khz. The signal from driver is square waveform. How to understand the circuit ?
Can you give more information or you don't know anything about it?
This is a sort of filter. Because the inductor values are missing it is dificult to guess what it does. Maybe it is some harmonics filter, it can have three peaks.
This part is used as antenna of 125khz transceiver. I think that L1, L2, L3 and c4~c10 consist of a resonance circuit. But I don't know if it is right.
what action do c2,c3 and L4,L5 have?
draw into a simulator fire it up and graph it see what it does
what kind of a driver is the driver. What about the opamp circuit.
These can give some clear clue about the job of the circuit.
Pls give these details.
