Ant,
If you put a piezo on the secondary of a transformer with a 1:19 ratio then the piezo capacitance will be reflected by the turns ratio squared. So, you will end up with a huge reflected capacitance on the primary and resonance of the primary inductance with that reflected capacitance could be an issue. The other way to look at it is that the secondary inductance is the primary inductance multiplied with the square of the turns ratio and that resonates with the piezo capacitance. Same result - one is transferring everything to the primary side, the other to the secondary side.
Keith.
The most interesting point is the real part of the transducer impedance, that has to be matched to the generator's optimal load impedance by the transformer.
The only enamelled core I can find are these, the reels are a bit long though.
I sayed optimized load impedance rather than source output impedance. It's simply the impedance that allows maximum output power. The basic assumption is, that you are able to cancel the reactive load at the transformer primary side and set a transformer voltage ratio, that transfers maximum power to the real part of the transducer impedance.I find this bit difficult. The generator is an opamp which should in theory have a low output impedance.
It depends on, if you are understanding the basic theory behind piezo transducer and related AC network bevaviour.I hope I'm not still building this circuit in 35 years
Some catalog districutors and DIY shops should have smaller (e.g. 100g) coils. As a student, I got my magnet wire to build transformers from a motor repair workshop around the corner.The only enamelled core I can find are these
Transducers have a series resonance (minimum impedance) and a parallel resonance (maximum impedance). Usually the series resonance is utilzed for transmitters. In any case, it would be good to know the real impedance. Depending on the application, it may vary with the mechanical transducer load, e.g. for an ultrasonic cleaner. It can be even useful, to allow a generator frequency tuning for maximum transmitted power in these cases.as the piezo operates at resonance its impedance drops to the minimum, this is usually less than 100 ohms
