dra66ard
Newbie level 5
How do I connect my Vss for my testbench ?
Hi, i was doing my testbench in Mentor Graphic. I was doin the test for my rail-to-rail op amp therefore i would need to use Vss instead of ground and i was confused on how to connect my Vss. I attached along the picture for my testbench circuit as reference. Currently, i connected my Vss to the negative terminal of 0Vdc and the positive terminal of 0Vdc is connected to ground. Please advise me on this, your help is highly appreciated. Thank you =)
