nevetts
Can anyone tell me the best way to simulate mutliple thin layers in HFSS. I'm currently having problems with the layered impedance boundary...
I'm simulating the effect of a thin layer of Nickel Chromium underneath a thin layer of gold on the wall of a rectangular cavity operating at the fundamental mode (TE101). To impose this boundary condition I use the layered impedance boundary.
If the thickness of the gold is less than the skin depth I was expecting the cavity to become very lossy and for the Q to become much smaller. However when I set the thickness of the gold to be many skin depths I expect the cavity Q not to depend at all on how much nichrom is behind it. Unfortunately the HFSS result shows that, even for 1cm of gold, the cavity Q begins to drop for about 100 microns of nichrom.
Ideally I'd like to be able to trust the results for about 10nm of gold and 3 microns of nichrom but since the limiting case (lots of gold) is so clearly wrong I'm not sure I set the simulation up right.
Did I use the layered impedance boundary wrong???
The HFSS file is uploaded. Any help is appreciated!
