Help me write a VHDL code for implementing 4 bits Register
Iuri
Member level 2
I'm beginner at VHDL and I was trying to implement a 4 bits Register, but I have no idea of how to do it. The code below is what I got at this moment:
library ieee;
use ieee.std_logic_1164.all;
entity Register4Bits is
	port ( 	D0, D1, D2, D3 :	inout std_logic;
			WR : in std_logic	);    -- W = 0 , R = 1
end Register4Bits;
architecture archRegister4Bits of Register4Bits is
begin
	WriteRead : process ( WR )
	begin
			if WR'event and WR = '1' then
			elsif WR'event and WR = '0' then
			end if;
	end process;
end archRegister4Bits;
Please, someone can set me a direction?
thank you very much!
Re: VHDL 4 bits Register
for a register you need a clock. the code you have written is treating the WR signal as if it is a clock using both edges, which is not supported in FPGAs.
You need to follow the following code template for registers.
entity reg is
port (
  clk : in std_logic;
  d : in std_logic;
  q : std_logic
architecture rtl of reg is
begin
  process(clk)
  begin
    if rising_edge(clk) then
      q <= d;
    end if;
  end process;
end rtl;
it works fine! thx man!
this is a little piece of a bigger project... i have to build a ALU of Intel 4004 for a college.
more doubts is comming!
