If for the full scale input of 10V the full scale output is 10kHz, the relation between input and output is:
1mV <=> 1Hz ( 10000mV <=> 10000Hz)
So, if you need 1.22mV <=> 1Hz, you will need to reduce every 1.22mV to 1mV ..
In this case, use a simple 2-resistor voltage divider (for example, 2.2kΩ and 10kΩ) and divide the control voltage (before feeding it to Rin=100kΩ) in the ratio 1:1.22 ..
