bhargav32004
Junior Member level 2
Help in Ie3d
I am designing a patch antenna with a W shape ground plane. I obtained the W ground plane by using 2 ground layers. By connecting the vertices of polygons on the two layers I obtained the bent structure and then deleted the polygons.....How do i fill the region between with air dielectric.......Is this the correct way to construct a W or inv V shape ground plane.........?? or is there any other way.....please help me........
