Stardom
Newbie level 6
prototype pcb wire socket breadboard -wiki
Hey! I'm designing a project in which i want to use a strip of holes in which you can push a wire, just like a breadboard. I am having trouble identifying what should be used for this.
Should i use a straight female pin header (but they have no spring clip?)
Should i use IDC sockets?
I don't want to use anything like terminal blocks, as they are bulky and more expensive.
Thanks!
Edit: I almost forgot. I also want the user to be able to plug the pcb board into a breadboard, so this part should have through hole pins which are capable of fitting into a breadboard.
Thanks!
