Grounding extra pins in Bel Steward mag jack
dilan2005
Member level 4
hi
i found following mag jack for bel steward and there are two extra pins come out from
center taps of transformers.(P10 , P11 as in the figure) for proper operation do i need to ground these connection through a cap & resistor.
what is the resistor value i should use!
thanks a lot
regards
dilan
magjack
resistor 75 OHM cap 1nF
Re: magjack
is there an advanced magjack that has all components needed internaly so just connecting magjack to enc28.. chip to be enough?
