fringe capacitance calculation
fringing capacitance
Do not use adjacent metal layers and keep distance between wires especially differential ones.
fringe capacitance formula
can u plz tell me what is Fringe Capacitance
fringing capacitance calculation
Is there any material about fringe capacitance?
Anybody can upload lt?
thanks!
fringing capacitance formula
Fringe capacitance means the capacitance from the side wall of a material to any other object around it
To minimize it, only way is to put object far apart from each other
fringe capacitance
Also make your caps have a high ratio of area to perimeter.
what is fringe capacitance
yes, larger unit area minimizes fringe capacitance.
fringing cap
but larger unit area increases also unit perimeter!!!
moreover, larger unit area increases the total area of your circiut!!!
for me, the better solution is to use metal of different layer to route the circuit.
fringe cap
consider having a square with an area of 4square unit.
i think the perimeter of it is lesser than the total perimeter of 4 squares having 1 square unit each. that is what i mean.
capacitance fringe
I think this is to minimize the uncertainty of the cap absolute value !
calulating capacitor fringing
yes you are right. and that uncertainty is due to the effect of the fringe capacitance.
nowadays, there is formula for getting the actual value of the capacitor and fringe capacitance is already included in the calculation.
fringe capacitance model
No - the reason to maximize the perimeter has to do with the fact that fringing capacitance is proportional to perimeter of the cap. When we model a parallel plate cap, we disregard the fringing capacitance and say that all of the capacitance is due to the area. We can't make this assumption when there is a large perimeter.
Look up Hajimiri & Lee's paper of lateral flux capacitors (fractal capacitors) for more information.
As far as mismatch / uncertainty goes, Pelgram shows that the variance of capacitance is inversely proportional to cap area.
capacitance calculation fringe
Fringe capacitance depends on the layer. For metals, upper layers are thiker and so there is more fringe capacitance between two upper metal layers with the same kind.
calcuration fringe capacitance
It may help you to understand more on Fringe Cap quantitively
I found this which might be useful
Section 3.3 talks about Fringe Caps.
Dave C
  • Capacitance_Calcs.pdf
Reactions: jjr and mvj
    mvj
    jjr
