Morell
Member level 1
Hi Guys
I need your help again.
Here is the Scenario of what I want to do :
1- I have and input that is std_logic_vector (N downto 0) and 5<N<31.
N is a Generic.
2- I want to send this input (5 to 31 bits) with my serial transmitter.
I am going to Discribe that I plan to do, if u have any suggestion, tips advices and etc
please reply to this thread.
My Plan :
1- I set the Transmitter as the top module, so from now on, everything happens in the transmitter.
2- In this module , I have a state machine. At first I would convert this string to bytes.
I have a component called Str2Bytes(). In the first state I use the output of this component.
Let's assume that the component works perfectly (I didn't design it yet).
For example : N is equal to 18. We pass 18 bits to Str2Bytes() and it gives us Three Bytes.
First byte : Output_byte_Reg(2) = (23 downto 16) = 000000XX (The only bits that we need
are the two right bits).
Second byte : Output_byte_Reg(1) = (15 downto 0)
Third Byte : Output_byte_Reg(0) = The least significant 8 bits (7 downto 0)
3- When Str2Bytes() finished (For example with a flag named Finished_Reg) then we go to the
next state. This state is called Set_Data. In this state we put one of those Output_byte_Reg(i)
in another signal (Data_Out_Reg). Data_Out_Reg is the signal that is sent bit by bit.
Now we go to the next state (Transmit).
4- In this state, we send the data bit by bit (This part is designed and implemented on the board
and worked). After that we go back to Set_Data state and read the next byte until the all the
bytes have been sent.
So right now i think that the Str2Byte() should do the FIFO job too. But i have no idea how to synchronize Str2Byte() with the top module (Transmitter).For example how can I tell the Str2Bytes() to give me the next byte or how can I find out that all the bytes have been sent and the
Str2Bytes() (Which is also a FIFO too) is empty and so on. Basically I don't now how to control this component with the top module.
1- If you think my plan has a problem please tell me and give me your suggestion pleas.
2- If you think it is right, just tell me what should i design first? (Str2Bytes , Transmitter?)
and what are the control signals? and the inputs and outputs that is necessary for these modules.
Right now I am trying to write what I've just Discribed and I will post the codes a.s.a.p.
I would greatly appreciate it if you kindly give me some advices on this research.
Thanks alot.
N is a Generic.
My Plan :
Thanks alot.
