[SOLVED] Difference between the Schematics of MOS varactors
umberabbas
I want to use varactors to get the tuning curves but I am confused as to which varactor should be chosen among the available. Also, can the varactor type be identified by looking at the schematic? Attached is the figure for the reference. It's a NMOS varactor but is it a accumulation or an inversion MOS? vrac.png
please also describe how to simulate this varactor to get Cg/Vg or Cg/Vtune curves?
No one can know what varactor are available except for you.
No.
See layout and masks.
Do AC analysis of single frequency point with sweeping Vg.
There ought to be a library document telling you the
applications purposes, device details, constraints and
performance of the elements. This may be a "modeling
document" or it may be a "device applications guide"
but any well run CAD group would have this kind of
collateral either bundled with the PDK or available for
download on foundry support pages.
You may care about other things than C and voltage
range, for example series R and L. That all depends a
lot on the layout details as well as operating point and
device vertical construction.
Please have a look and let me know whether I am doing it right or not.vrac1.pngnetlist1.pnggraph1.png
What value do you apply as "vctrl" ?
And what are "net4" and "net03" ?
I assume MOS varactor of attached figure.
Is "net4" "G" ?
Is "net03" "S/D" ?
Save terminal current of C1.
Then reshow netlist as text not image.
Vcntrl and Vs both as 0.1 v.
net03 is the gate to V node and net4 is the node of G to Vg.
-------NETLIST----------
simulator lang=spectre
global 0
parameters vcntrl=100m Vg=100m
View name: schematic
C1 (net4 net03 0) nvar_12rf w=(2u) l=(2u) ny=3 nx=3 m=1
Vg (net4 0) vsource dc=Vg mag=1m type=sine freq=60G
Vcntrl (net03 0) vsource dc=vcntrl type=dc
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \
checklimitdest=psf
ac ac freq=60e9 param=Vg start=10m stop=300m step=10 annotate=status
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
dc dc param=vcntrl start=10m stop=300m step=0.1 oppoint=rawfile \
modelParameter info what=models where=rawfile
element info what=inst where=rawfile
outputParameter info what=output where=rawfile
designParamVals info what=parameters where=rawfile
primitives info what=primitives where=rawfile
subckts info what=subckts where=rawfile
save C1:1 C1:2
saveOptions options save=allpub
I have labelled the schematic for more clarity. I hope this will be sufficient.
test_umberabbas.scs
// Generated for: spectre
// Generated on: Nov 24 10:45:50 2017
// Design library name: kkk
// Design cell name: test_umberabbas
// Design view name: schematic
global 0
parameters Vg=1 Vsd=0 my_freq=1G
include "ttt.scs"
// Library name: kkk
// Cell name: test_umberabbas
// View name: schematic
L1_feed1 (G net05) dcfeed l=1u
L1_feed2 (SD net03) dcfeed l=1u
V1 (net03 0) vsource dc=Vsd type=dc
V0 (net05 0) vsource dc=Vg type=dc
PORT2 (net052 0) port r=100K num=2 type=dc
PORT1 (net07 0) port r=100K num=1 type=dc
C1 (G SD 0) moscap_rf_nw wr=2.5u lr=0.5u br=10 gr=2
C1_block1 (G net07) dcblock c=1u
C1_block2 (SD net052) dcblock c=1u
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=25.0 \
    tnom=25.0 try_fast_op=no scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
    maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output" checklimitdest=psf
sp sp freq=my_freq param=Vg start=-1 stop=1 lin=1000 annotate=status
saveOptions options save=allpub pwr=none currents=all
Skill Code Fragments for Post Processing
omega = 2 * acos(-1) * VAR("my_freq")
z11 = zpm('sp 1 1)
z12 = zpm('sp 1 2)
z21 = zpm('sp 2 1)
z22 = zpm('sp 2 2)
Z1_diff = (z11 + z22) - z12 - z21
C1_diff = imag(1 / Z1_diff) / omega
Thank you a million times. You are a lifesaver :) :)
