DDR3 memory Interface
rocking1234
Member level 1
India
Hi
I am desiging for a ddr3 memory interface controller for 1GB micron DDR3. I have attached the micron IGB Functional Block diag. It says 1GB : 128M X 8.
The problem is how do I fix the row address and the column address. I know that for one DDR3 consist of 8 bank. So to fix the address 3 bits are used of bank addressing and I am confused how to choose the Row address and column address.
Any help would be very much appricitaed .
hi...if im not wrong...the row address and the column address has being mention the micron datasheet..or you can get it in the JEDEC spec (JESD79-3D) in page 29.
