TH22
Newbie
Hello,
I need some help with stimulating coupled striplines using Sonnet.
The coupled line consists of two strips with 4 ports. The lines have the same dimension and shared ref plates. I need to calculate the coupling coefficient of the lines for various spacings between the lines. How can I extract the Self Inductance of each of the strip transmission line as well as the mutual inductance using Sonnet?
Is there any equation for the coupling coefficient between lines in Sonnet?
Thank you
Thank you
