constraining a generated clock that is also an output?
casey480
Junior Member level 1
i have a generated clock 'i_clk' which is a divide by two created from a flip flop clocked by 'user_clock'
thus, i have the following constraint:
create_generated_clock -source [get_pins user/user_clk_mux/O] [get_pins user/i_clk_reg/Q] -name I_CLK -divide_by 2
i_clk is also an output of the module. my question is, how do I constrain that output?
i currently have
set_output_delay -max 16 -clock I_CLK {i_clk}
however, I get min timing violations on that port. Am I doing this correctly?
set_output_delay -min 16 -clock I_CLK {i_clk} may fix it but I don't think set_output_delay is the proper way to constraint output clock (its usually for data paths and not clock paths). If you have a certain timing to the output you have to meet you can use set_max_delay/set_min_delay
    casey480
