supersage
Member level 3
Hi all,
Now I am using IE3D to design an patch array antenna at 60 GHz and need to design a T junction. The output arms have characteristic impedance of 50 ohm with the corresponding width of 0.21988 mm, and the input arm has a quarter-wavelength transformer whose characteristic impedance of 35.56 ohm with the corresponding width of 0.3952 mm, in order to transform the impedance to 50 ohm at the input terminal. I am wondering the chamfer size of such a T junction in IE3D!!! In addition, could you please tell me the typical chamfer size of a T junction? Thank you very much!
Sincerely yours,
Sincerely yours,
