govandi999
vhdl elsif hex
In this design, we have to capture the behavior of a password attacking mechanism (Bruteforce) by writing a behavioral VHDL code.
Mechanism
We have an input "DATA" of size 8-bit. The password would be somewhere between 00 to FF (hex). We will set the input at say 1C (hEX) . The attack will start from this input say 1C and it will scan through upto FF. We have another input "START". It means when START ='1' then the password attacking begins. An 8-bit password is already stored in a variable inside the code. If the system finds the correct password then it will stop at that number. If not, then it stops at FF (hex).
If someone can initiate the design for this problem. Pl. post it here
Mechanism
