canno write in rom in place and route while it works in behavioral
qwerty_asdf
Member level 4
Well prolem is what is mentioned.
In my code i read 32bit data from a file, and store them in a ram of 8 bits datas (and 4 more times indexes.) In behavioral it works perfectly. But in place and route my ram stays always in 00000000. The result it the same either if i implement my own ram or create one with coregen.
Here is my code with some comments:
component filter_1_1 is
  generic
		(data_length :integer := 8;
		address_length:integer:=7 ;
		comp_num:integer:=4;
		total_number:integer:=2);
		port ( clk:in std_logic;
		--vin:in std_logic;
		rst:in std_logic;
		mem_data:in std_logic_vector(data_length-1 downto 0);
		set: in std_logic;
		mem_address: in std_logic_vector(address_length downto 0);
		wea: in std_logic;
		finished:in std_logic; --when L it stills sends data to filter, when H data send.
		dout: out std_logic_vector(3*data_length-1 downto 0);
		done: out std_logic
end component;
component rom1 IS
	GENERIC
		ADDRESS_WIDTH	: integer := 7;
		DATA_WIDTH	: integer := 8
	PORT
		clock			: IN  std_logic;
		data			: IN  std_logic_vector(31 DOWNTO 0);
		write_address			: IN  std_logic_vector(7 DOWNTO 0);
		we			: IN  std_logic;
		q			: OUT std_logic_vector(31 DOWNTO 0)
end component;
signal input_data: std_logic_vector(31 downto 0);
begin
reading_from_file: rom1 generic map(ADDRESS_WIDTH=>total_number, DATA_WIDTH=>3*data_length) port map(clk,input_data,address,wea_controller,temp_data);
passing_to_filter: landmark_1
generic map(
data_length=>data_length,
address_length=>address_length,
comp_num=>comp_num,
total_number=>total_number
) port map (
	clk=>clk,
	--vin=>vin,
	rst=>rst,
	mem_data=>mem_data,
	set=>set,
	mem_address=>mem_address,
	wea=>wea,
	finished=>finished,
	temp=>temp,
	dout=>dout,
	temp_in_1=>temp_in_1,
	temp_in_2=>temp_in_2,
	temp2_sum=>temp2_sum
dout_temp<=mem_data;
core_address<=mem_address;
dout_res<=temp;
where mem_data is the data passed to filter_1, and mem_address the address to write in filter_1 memory.
From my place and route simulation those signals get the right value.
Here is the part of my filter_1 code.
component ram3 IS
	GENERIC
	PORT
		data			: IN  std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
		read_address			: IN  std_logic_vector(7 DOWNTO 0);
		we			: IN  std_logic;
		q			: OUT std_logic_vector(DATA_WIDTH - 1 DOWNTO 0)
end component;
data_read_1: ram3 generic map(ADDRESS_WIDTH=>total_number, DATA_WIDTH=>data_length) port map(clk,din,address_A,address_A,wea_1,out_temp);
address_A<=mem_address;
din<=mem_data;
wea_1<='1';
and here are some warnings I get in ISE.
Xst:1432 - Contents of array <ram_block> may be accessed with a negative index, causing simulation mismatch.
Xst:1433 - Contents of array <ram_block> may be accessed with an index that exceeds the array size. This could cause simulation mismatch.
Here os the code of my ram_3.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY ram3 IS
	GENERIC
	PORT
		we			: IN  std_logic;
END ram3;
ARCHITECTURE rtl3 OF ram3 IS
	--TYPE RAM IS ARRAY(0 TO 2 ** (ADDRESS_WIDTH + 2)) OF std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
TYPE RAM IS ARRAY(0 TO 255 ) OF std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
	SIGNAL ram_block : RAM;
BEGIN
	PROCESS (clock)
	BEGIN
		IF (clock'event AND clock = '1') THEN
			IF (we = '1') THEN
			    ram_block(to_integer(unsigned(write_address))) <= data;
				--ram_block(write_address) <= data;
			END IF;
			q <= ram_block(to_integer(unsigned(read_address)));
			--q <= ram_block(read_address);
		END IF;
	END PROCESS;
END rtl3;
