john.zhang
Newbie level 5
Hi all,
I am designing a two stage LNA, and so I am using the Sprobe to check for the stability.
there is a "stab index" function in the sprobe for the sp analysis, however I am unsure how to use it. For stability FACTOR, I know it has to be greater than 1, and my circuit indeed does have stability factor (k) greater than 1. However, for stabfactor in sprobe, the results I get are less than 1, it even goes to the negative value .
Cadence says this
So I am confused, is it |stab factor| < 1 for stability?
is a stab factor of negative alright? this just means that one of my gamma is less than 50 real value, right?
Cadence says this
