First the element should be right-hand or left-hand circular polarization. Then design the feeding network for the array. You could follow the example in the antenna books or papers.
Not necessarily only RH or LH. The patch can be dual-linear element with in front a 0-90° hybrids, the two hybrids port can be used for LH an RH Circular Polarization.
