ecwala
Newbie level 2
hi this is shikhar need help and guidance regarding apr 9600 voice recorder playback chip interfacing with 8051 nxp and programming . iam using only 4 msg to record in chip
pls reply soon
pls reply soon
In APR9600, you may record maximum of 60 seconds and playit back with different settings through the Buttons connected. So i suggested you to connect those buttons of the APR9600 to the pins/port of the 8051 which is programmmed in the way you need it to swicth. Thaz it. Refer the datasheet of the device for all the application circuits. Now dont ask me to design and post a complete project with schematics, code and PCB.ecwala said:pranam77.. i did't get u pls explain in detail thanks for reply
pls give thi pin discription also...
