underw
Newbie level 3
Why cross-polarization ratio is important for lineary polarized antennas?
The question reason is one test. I have two wifi 802.11n MIMO modules and did throughput test two times. At first time AccessPoint Tx0 signal goes through attn and cable only to STAtion Tx0, AP Tx1 -> STA Tx1. At second time AP Tx0 -> attn -> splitter + two cables to STA Tx0 and STA Tx1; AP Tx1 -> attn -> splitter + two cables to STA Tx0, Tx1.
Throughputs are same at booth test-setups.
I also did test on 10km link - I change AP antenna (linear polarization) with ~30dB cross-polarization ratio to antenna with ~15dB cross-polarization ratio and throughput (155Mbps) doesn't change. Datarate is 300Mbps (40MHz, 2x2, MCS15), but real throughput is only ~155Mbps - it's maximal throughput of those wifi modules.
So, seems that for MIMO wifi antenna cross-polarisation ratio isn't important. Where I'm wrong?
