AC/DC Current and Volage Digital Meter
hifni
icl7017
I want to make an AC/DC Current and Volage Digital Meter..
Does anyone know the best methode for this..
Thx,
dc current meter
If you want to make a DC Current or Voltage Digital meter, you can use an Intersil's ICL7107 (LED display) or ICL7106 (LCD display), depending on your desired display medium. Microchip also has versions of the mentioned IC's namely TC7107 and TC7106 plus an improved versions in TC7117 and TC7116. You can check the menufacturer's website about infos on this IC's. They are integrating ADC's, and are really meant for digital display. The input for these IC's are DC. The 7107 and 7106 comprise the digital processing circuitry, but you also have to provide for the analog signal conditioning portion (like attenuators) to properly interface the analog signal to the analog input of the IC.
As for the AC digital meter, you have to add a module that somehow "converts" the AC to DC, so that the resulting DC would have parameters that are proportional to the properties of the AC input. Probably you can use a bridge rectifier, or other rectifiers, or RMS-to-DC converter. Analog Devices has plenty of the latter. Hope this helps.
dc current & dc voltage meter using 7107
Will you build the meter from scratch with a microcontroller or so or what? Or you intend to use dedicated chips?
how to make a digital current meter
I want to build it from scracth using uC? Any help/idea?
modulo display icl7106
Now, I have some problem with my Digital Voltage Display using ICL7017.
Powered by a +5 Vdc Power supply, producing -5Vdc using NOT gate (as indicated in this attached file, this file is posted by someone in this forum, but sorry that I had modified and can not know who is the author)
But when I connect 0 Volt to IN of 7107, it don't display 0V (around 0.5V)
How can I fix this problem?
