sector9
Junior Member level 1
I am using mikroc and this is the code
USBdsc.c
![Capture.PNG Capture.PNG](https://www.edaboard.com/data/attachments/37/37980-8f7dbae7a3b2275f9f74a887309ea947.jpg)
![DSC_0285.jpg DSC_0285.jpg](https://www.edaboard.com/data/attachments/37/37981-05e3e1f42deb9627fd0a3fbc5e293322.jpg)
xtal is 20MHZ cap. is 0.47uf
when i plug it in to the usb nothing happens at all ! where did i go wrong ?
thank you in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
unsigned char readbuff[64] absolute 0x500; // Buffers should be in USB RAM, please consult datasheet
unsigned char writebuff[64] absolute 0x540;
char cnt;
char kk;
void interrupt(){
USB_Interrupt_Proc(); // USB servicing is done inside the interrupt
void main(void){
ADCON1 |= 0x0F; // Configure all ports with analog function as digital
CMCON |= 7; // Disable comparators
HID_Enable(&readbuff,&writebuff); // Enable HID communication
while(1){
while(!HID_Read())
for(cnt=0;cnt<64;cnt++)
writebuff[cnt]=readbuff[cnt];
while(!HID_Write(&writebuff,64))
USBdsc.c
const unsigned int USB_VENDOR_ID = 0x1235;
const unsigned int USB_PRODUCT_ID = 0x0001;
const char USB_SELF_POWER = 0x80; // Self powered 0xC0, 0x80 bus powered
const char USB_MAX_POWER = 50; // Bus power required in units of 2 mA
const char HID_INPUT_REPORT_BYTES = 64;
const char HID_OUTPUT_REPORT_BYTES = 64;
const char USB_TRANSFER_TYPE = 0x03; //0x03 Interrupt
const char EP_IN_INTERVAL = 1;
const char EP_OUT_INTERVAL = 1;
const char USB_INTERRUPT = 1;
const char USB_HID_EP = 1;
const char USB_HID_RPT_SIZE = 33;
/* Device Descriptor */
const struct {
char bLength; // bLength - Descriptor size in bytes (12h)
char bDescriptorType; // bDescriptorType - The constant DEVICE (01h)
unsigned int bcdUSB; // bcdUSB - USB specification release number (BCD)
char bDeviceClass; // bDeviceClass - Class Code
char bDeviceSubClass; // bDeviceSubClass - Subclass code
char bDeviceProtocol; // bDeviceProtocol - Protocol code
char bMaxPacketSize0; // bMaxPacketSize0 - Maximum packet size for endpoint 0
unsigned int idVendor; // idVendor - Vendor ID
unsigned int idProduct; // idProduct - Product ID
unsigned int bcdDevice; // bcdDevice - Device release number (BCD)
char iManufacturer; // iManufacturer - Index of string descriptor for the manufacturer
char iProduct; // iProduct - Index of string descriptor for the product.
char iSerialNumber; // iSerialNumber - Index of string descriptor for the serial number.
char bNumConfigurations; // bNumConfigurations - Number of possible configurations
} device_dsc = {
0x12, // bLength
0x01, // bDescriptorType
0x0200, // bcdUSB
0x00, // bDeviceClass
0x00, // bDeviceSubClass
0x00, // bDeviceProtocol
8, // bMaxPacketSize0
USB_VENDOR_ID, // idVendor
USB_PRODUCT_ID, // idProduct
0x0001, // bcdDevice
0x01, // iManufacturer
0x02, // iProduct
0x00, // iSerialNumber
0x01 // bNumConfigurations
/* Configuration 1 Descriptor */
const char configDescriptor1[]= {
// Configuration Descriptor
0x09, // bLength - Descriptor size in bytes
0x02, // bDescriptorType - The constant CONFIGURATION (02h)
0x29,0x00, // wTotalLength - The number of bytes in the configuration descriptor and all of its subordinate descriptors
1, // bNumInterfaces - Number of interfaces in the configuration
1, // bConfigurationValue - Identifier for Set Configuration and Get Configuration requests
0, // iConfiguration - Index of string descriptor for the configuration
USB_SELF_POWER, // bmAttributes - Self/bus power and remote wakeup settings
USB_MAX_POWER, // bMaxPower - Bus power required in units of 2 mA
// Interface Descriptor
0x09, // bLength - Descriptor size in bytes (09h)
0x04, // bDescriptorType - The constant Interface (04h)
0, // bInterfaceNumber - Number identifying this interface
0, // bAlternateSetting - A number that identifies a descriptor with alternate settings for this bInterfaceNumber.
2, // bNumEndpoint - Number of endpoints supported not counting endpoint zero
0x03, // bInterfaceClass - Class code
0, // bInterfaceSubclass - Subclass code
0, // bInterfaceProtocol - Protocol code
0, // iInterface - Interface string index
// HID Class-Specific Descriptor
0x09, // bLength - Descriptor size in bytes.
0x21, // bDescriptorType - This descriptor's type: 21h to indicate the HID class.
0x01,0x01, // bcdHID - HID specification release number (BCD).
0x00, // bCountryCode - Numeric expression identifying the country for localized hardware (BCD) or 00h.
1, // bNumDescriptors - Number of subordinate report and physical descriptors.
0x22, // bDescriptorType - The type of a class-specific descriptor that follows
USB_HID_RPT_SIZE,0x00, // wDescriptorLength - Total length of the descriptor identified above.
// Endpoint Descriptor
0x07, // bLength - Descriptor size in bytes (07h)
0x05, // bDescriptorType - The constant Endpoint (05h)
USB_HID_EP | 0x80, // bEndpointAddress - Endpoint number and direction
USB_TRANSFER_TYPE, // bmAttributes - Transfer type and supplementary information
0x40,0x00, // wMaxPacketSize - Maximum packet size supported
EP_IN_INTERVAL, // bInterval - Service interval or NAK rate
USB_HID_EP, // bEndpointAddress - Endpoint number and direction
EP_OUT_INTERVAL // bInterval - Service interval or NAK rate
const struct {
char report[USB_HID_RPT_SIZE];
}hid_rpt_desc =
{0x06, 0x00, 0xFF, // Usage Page = 0xFF00 (Vendor Defined Page 1)
0x09, 0x01, // Usage (Vendor Usage 1)
0xA1, 0x01, // Collection (Application)
// Input report
0x19, 0x01, // Usage Minimum
0x29, 0x40, // Usage Maximum
0x15, 0x00, // Logical Minimum (data bytes in the report may have minimum value = 0x00)
0x26, 0xFF, 0x00, // Logical Maximum (data bytes in the report may have maximum value = 0x00FF = unsigned 255)
0x75, 0x08, // Report Size: 8-bit field size
0x95, HID_INPUT_REPORT_BYTES,// Report Count
0x81, 0x02, // Input (Data, Array, Abs)
// Output report
0x95, HID_OUTPUT_REPORT_BYTES,// Report Count
0x91, 0x02, // Output (Data, Array, Abs)
0xC0} // End Collection
//Language code string descriptor
const struct {
char bLength;
char bDscType;
unsigned int string[1];
} strd1 = {
4,
0x03,
{0x0409}
//Manufacturer string descriptor
const struct{
char bLength;
char bDscType;
unsigned int string[10];
}strd2={
22, //sizeof this descriptor string
0x03,
{'s','e','c','t','o','r','I','N','D','2'}
//Product string descriptor
const struct{
char bLength;
char bDscType;
unsigned int string[4];
}strd3={
10, //sizeof this descriptor string
0x03,
{'g','p','s','2'}
//Array of configuration descriptors
const char* USB_config_dsc_ptr[1];
//Array of string descriptors
const char* USB_string_dsc_ptr[3];
void USB_Init_Desc(){
USB_config_dsc_ptr[0] = &configDescriptor1;
USB_string_dsc_ptr[0] = (const char*)&strd1;
USB_string_dsc_ptr[1] = (const char*)&strd2;
USB_string_dsc_ptr[2] = (const char*)&strd3;
