12V E Scooter Relais Start Problems
rolg1
Newbie level 2
london/uk/europe
This scooter has a Songle SLA 12VDC SL-A relais and two 2pole switches. One switch is the foot control on-off. The other switch cuts a circuit when pressing the brake pedal. Manually engaging the relais starts the motor. As long as the motor is in motion the on off footswitch stops and starts the motor via the relais.
Once the motor stops for more than half a second pressing the footswitch has no more effect on the relais.
Any ideas welcome Rol
Hi, are u trying to say that the relay has a timer or sensor that dis engaged the on/off swich when ever the motor start moving?
Hi
Thanks, There is no timer.
I think I figured out that it is deliberately designed in this way.
In operation it works like this.
1. Switch on main power switch
2. Start the scooter manually while pressing the foot switch
3. Once the rear wheel turns the motor via the drive belt the on/off footswitch operates the relays ok
Why or how it's done this way seems the only part of the puzzle I need to solve now.
Regards
Hello, can you post the schematic diagram, to analys it well.
