110 Vac to binary 1 and 0
skorper
Newbie level 6
optocoupler application ac mains monitoring
I am looking to sense a 110 Vac input while outputting a binary 1 or 0 (+5v for sensing 110 Vac and 0v for when 110 Vac is turned off).
The binary needs to be the input to a PIC microcontroller.
you can use a transformer to step down to 5V
use a diode to rectify and a capacitor.
when the pic measures the capacitor voltage, when it detects 5V 100VaC is on line
Use a SPDT Relay
AC mains monitoring can be done with optocouplers .. see pictures below ..
Detailed description of these circuits can be found at:
(download the PDF version) ..
Regards,
IanP
    skorper
Considering the extent of what I am trying to accomplish, transformers would be too bulky. Relays would probably introduce contact bounce.
The opto solution looks to be the best. I will research and calculate to try a viable solution.
Thank you one and all for your valued input.
Quote: "There are no WRONG answers. Only answers that apply to different questions"
by; Annonymous
:D
