10% Duty Cycle in VHDL
missbirdie
Member level 1
Egypt
duty cycle vhdl
How can I implement in VHDL a 10% Duty cycle clock from the 50 MHz clock in spartan 3 ??
vhdl duty cycle
What frequency output clock do you need?
writing vhdl code to get 50% duty cycle clock
100 KHz
vhdl simulation duty cycle
I'm no good at writing VHDL, but maybe this Verilog module will help you. It's a 10-bit counter that continuously counts up from -50 through +449. The most significant bit is output through a clock buffer, for high fanout and low skew, suitable for clocking other synchronous logic. (I don't know if you really need that buffer.) When the input clock is 50 MHz, the output is a 1us pulse every 10us.
module top (clk, clkout);
  input             clk;    // synthesis attribute PERIOD clk "50 MHz";
  reg signed  [9:0] count=0;
  output            clkout;
  BUFG u1 (.I(count[9]), .O(clkout));  // clock buffer
  always @ (posedge clk)
    count <= count == 449 ? -50 : count + 1;
endmodule
    missbirdie
duty-cycle vhdl
use dcm or pll to get the duty cycle change
what is a duty cycle in a verilog hdl
hey !
check it this symbol and my simulation
tick_max output is 10% duty cycle of any input clock! is it ok??
the VHDL code is as below
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
entity M_counter is
generic (N: integer := 4;
M: integer := 10 );
port(
clk, reset: in std_logic;
q : out std_logic_vector ( N-1 downto 0);
max_tick: out std_logic
end M_counter;
Architecture arch_M of M_counter is
signal r_reg : unsigned ( N-1 downto 0);
signal r_next : unsigned ( N-1 downto 0);
-- register
begin
process(clk, reset)
begin
if (reset='1')then
r_reg<= (others=>'0');
elsif (clk'event and clk='1')then
r_reg<=r_next;
end if;
end process;
--next state logic
r_next<= (others=>'0') when r_reg = (M-1) else
r_reg+1;
--output logic
q<= std_logic_vector (r_reg);
max_tick <= '1'when r_reg=(M-1) else'0';
end arch_M;
