+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 1
    Points: 882, Level: 6
    Join Date
    Feb 2016
    Posts
    116
    Points
    882
    Level
    placing of patch antenna on ebg mushroom
    Hi i am bit confused about the ebg mushroom type antennas. how the patch is placed on the ebg structure. is it (patch+substrate without ground) is placed on the ebg structure which acts like a ground. or we make the ebg structure and remove some of the cells so that patch can be placed. in this case patch and ebg substrate are common and all the metal layer(patch + ebg cells) are in same plane.
    •   Alt10th January 2017, 12:33
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Re: placing of patch antenna on ebg mushroom
    Both have been done, but I'd say the first is definitely more common.
    •   Alt10th January 2017, 16:22
      advertising
  3. #3
    Full Member level 1
    Join Date
    Feb 2016
    Posts
    116
    Points
    882
    Level
    so they also keep the whole patch(patch+substrate+patch ground) directly on top of ebg. in this case the ground of patch will be in touch with the ebg surface metal. take a look at the paper i've attached.
    or did they removed the metal from the place where patch was fabricated, and if they did how to calculate the metal clearace area so that patch can be placed.
