+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 1
    Points: 733, Level: 5
    Join Date
    Nov 2008
    Posts
    Points
    733
    Level
    fence charger circuit
    please tel me how to design electric fence energizer using microcontroller or using digital ic ?
  2. #2
    Full Member level 2
    Points: 2,163, Level: 10
    Join Date
    Jan 2005
    Solar System
    Posts
    129
    Points
    2,163
    Level
    10
    electric fence circuit diagram
    Do you mean by the fence to keep people away. Charge a capacitor to A.C mains voltage through a very high resistance connected at the phase side so that the person is not electrocuted. The capacitance of the capacitor determines the length of the shock. The fence will get the wire from the other end of the resistor.
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 239,524, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,499
    Points
    239,524
    Level
    100
    electric fence energizer circuit
    means charge to no voltage.
    Wkipedia briefly tells about typical electrical fence parameters:
    A fence charger places an electrical pulse from ground to the wire about once per second. The pulse is narrow and usually around 5-20 kV. Animals receive an uncomfortable but harmless shock when contacting the wire, and learn to stay away from it.
  4. #4
    Full Member level 4
    Points: 3,327, Level: 13
    Achievements:
    7 years registered
    Join Date
    Apr 2006
    Posts
    233
    Points
    3,327
    Level
    13
    A few years ago I made an electric fence which worked quite well out of a motor car spark plug coil. I used a 555 timer to energize the coil every few seconds. I connected the gnd to a metal spike hit into the soil and the output of the coil went to the fence. I uses a 7ah 12v battery to power the system. It worked well on people (i tested it on myself) and horses. The horses very quickly learned not to attempt to break the paddock fence :)
  5. #5
    Full Member level 2
    Join Date
    Jan 2005
    Solar System
    Posts
    129
    Points
    2,163
    Level
    10
    electric fence energizer circuit diagram
    Quote Originally Posted by FvM
    Charge a capacitor to A.C mains voltage through a very high resistance means charge to no voltage.
    You are correct, I forgot to mention a diode in series so that capacitor is charged through D.C pulses.
  6. #6
    Junior Member level 1
    Points: 623, Level: 5
    Swagatam's Avatar
    Join Date
    Apr 2010
    mumbai
    Posts
    15
    Points
    623
    Level
    Re: fence charger circuit
    Please check out the folowing circuit of an electric fence charger developed by me:
    Homemade Circuit Designs Just For You: A Homemade Fence Charger, Energizer Circuit Explained.
  7. #7
    Newbie level 1
    Points: 198, Level: 2
    Join Date
    Nov 2011
    Posts
    Points
    198
    Level
    Quote Originally Posted by mangesh_c View Post
    I need 5J out put electric fence energizer circuit.P send me circuit diagram.
    thank you
  8. #8
    Newbie level 2
    Points: 161, Level: 2
    Join Date
    Feb 2012
    Posts
    Points
    161
    Level
    Re: electric fence circuit
    Quote Originally Posted by davidgrm View Post
    I was also used that method(motor car spark plug coil) . I used it for dogs and goats. A solar panel and a 12V motorcycle battery are enough for this.
    ---------- Post added at 11:40 ---------- Previous post was at 11:03 ----------
    you can make a energizer circuit by this steps, (1) make a circuit with digital IC and a powerful transistor for get out 10V-25V (40Hz-70Hz). (2) join that out put pulse cable to secondary coil of a transformer(6V-12V) and other secondary cable to GND of your circuit. (3) Now primary coils of the transformer should be connect to fence (make sure that both cables should be touch by animals)
    ---------- Post added at 11:55 ---------- Previous post was at 11:40 ----------
    ---------- Post added at 12:00 ---------- Previous post was at 11:55 ----------
    ---------- Post added at 12:01 ---------- Previous post was at 12:00 ----------
