What is the setup and hold time?
richardyue
Full Member level 1
setup and hold time
Hi, Members,
What is the setup and hold time? How do we use it in out application? Thanks in advance.
setup hold time
The setup and hold times refer to the stability requirements on the input and output data of a synchronous circuit.
Taking a D Flipflop (DFF) as an example:
The time [before the active clock edge] after which any change in the input data could result in the FF latching the wrong value is characterized as the SETUP time of that DFF.
The time [after the active clock edge] for which the DFF output maintains its value before switching is characterized as the hold time for that DFF.
The following figure shows setup and hold times for a DFF:
https://obrazki.elektroda.pl/77_1163170391.jpg
Reactions: mina_jean
    V
    mina_jean
setup time hold time
Does it mean that there is no requirement of the setup and hold time for an asynchronous circuit?
setup and hold time definition
for design with latches, we have another set of timing parameters called recovery and removal times.
setup time and hold time
we only check the reset recovery and removal.
Usually we are more concerned with setup and hold times for synchronous circuits since the operation of the circuit depends on the temporal relationship of two signals (clock and input data).
Ofcourse the same general concept applies to async circuits as well since a change in input data smaller in time than the gate can see (due to input capacitance) will result in no change at the output. However, in that case we are usually more interested in minimum input signal pulse width.
what is setup and hold time
Here is good article about the timing parameters . Hope it is helpful
  • timing_1261.pdf
hold time setup time
Timing is really a difficult thing to understand because I have no practical experince.
setup hold timing
its just a matter of time....u need to spend a little time and analyse...once u get a hang of it u'l have no problem with timing stuff...
hold and setup time
richardyue said:
Hi, Members,
please go through this so that u will be clear
hold setup time
Nice PPT vikram carryon ...
--Satya
setup and hold time
I absolutely have no idea.
setup & hold time
Thank you guys so much! it's very very helpful!!
hold time and setup time
As the name suggests it's really simple.U needn't think in terms of timing.
Think as if u r going to market.So before leaving u need to setup(eg. Give some time to urself to think about the list of things to bring etc.Also after coming from the market u need to take a little rest.Similarly in Digital circuits it will get rest if the data is changing atleast for that much time after the clock.
setup hold time
Hey vikram....
tats an excellent ppt......all my timing concepts hav been cleared.....
setup/hold time
have a look at this pdf
  • setup1_1210.pdf
set up and hold time
anyone have any slides or anything that has info on common techniques to deal with skew? i've heard they try to keep the hold times negative
stup and hold time
The documents you uploaded are very useful.
Many thanks.
setup hold time
hi,
I heard somewhere that the setup check is done with the next active edge but the hold check with the current edge itself..Is it so? If yes, why?
