Help me work with this 8051 programmer
Help
Advanced Member level 2
Anyone try this programmer before www.kmitl.ac.th/~kswichit/shiao/prog.htm, i already built the circuit but don't know how to program it to my chip (i using AT89C52)....
Please anyone know how to solve my problem or not....
Thanks...
Re: Programer 8051
It looks like the software was written for DOS, so you will need to re-start your computer in DOS (WIN95/98) or open Command Prompt (WIN XP, Accessories).
Put it in a new subdirectory and include there your HEX file .. and try again ..
Regards,
IanP
    Help
Re: Programer 8051
Q1) If my OS is Win2k is it can work??
Q2) Can you teach me how to generate the hex file beause i don't know how to use the uVision to generate, is it the uVision can generate teh hex file?
Thanks...
Re: Programer 8051
Q1: Win2k should be similar to XP ..
Q2: I don't use UVISION ..
Regards,
IanP
    Help
Re: Programer 8051
So, in this case what should i do?? Do you have any compiler and programmer which can give me to program my C code to my 8052 uC? I now using Win2K.
Thanks...
Re: Programer 8051
From your's another post I have learned that you can generate a HEX file.
About the programmer:
Maybe not everything is lost ..
I can't test it because I don't have your card attached to my computer but, as I mentined, Win2k can be similar to WinXP, and you can go to START/PROGRAMS/ACCESSORIES and find the "COMMAND PROMPT" option.
Have you tried it?
OR, do you know how to compose "commands" in the old DOS?
Regards,
IanP
    Help
Re: Programer 8051
What you mean?
I already put all the source file and software together in one folder.
I already try the command prompt. Is it i need do some setting about the parallel port??
Re: Programer 8051
Help,
my experience with "good old" dos programs which try to access serial or parallel port hardware directly under XP and 2000 is that it does normally not work ...
Try to find a windows program for your programmer hardware or use a computer with windows 95 oder 98 :)
best regards
    Help
Re: Programer 8051
This **broken link removed** programmer can support the Win2k or XP and it can program more uC. Do you try this programmer before?
I very worry after complete the circuit and the end it doesn't work like the first programmer.... :( ....
I hope everyone can me......
Thanks...
