PORTB in P18F4620 I/O problem
poxkix
Member level 5
I'm having problems in my 4620. In simulation I used PORTB as pins for my lcd and it works really fine.
When I interfaced it on a actual circuit nothing will happen.
The connections are 100% correct. No questions asked. No hardware problems too.
Now, I have read the datasheet and PORTB has interrupts. Are these interrupts in ON state by default and should be turned off?
I just want to make the PORTB as normal digital I/O.
This is the code I sued for the PORT setup:
INTCON = 0x00;
Is that correct? I don't quite understand the datasheet.
There are several possible issues:
1. Have you disabled the ADCs on RB4:RB0?
Note: On a Power-on Reset, RB4:RB0 are
configured as analog inputs by default and
read as ‘0’; RB7:RB5 are configured as
digital inputs.
By programming the Configuration bit,
PBADEN, RB4:RB0 will alternatively be
configured as digital inputs on POR.
2. RB7:RB6 are used for debugging. Have you disable debugging via configuration bits?
3. RB7:RB4 do have the interrupt on change feature and RB3:RB0 have external interrupt features.
Please post your code, so that one of us can examine it and advise you further. A schematic of your circuit was help as well.
BigDog
Reactions: poxkix
    poxkix
Simulators don't always incorporate all the hardware quirks (LCD delays are one of them).
Do you leave enough time for LCD to power-up (about 30ms should be more than enough), and also between the commands (or sample D7).
Use LATB for output instead of PORTB (that should be used for input).
BigDog
Here is the code:
I thought ADCON1 0xFF would turn off everything.
void PORTSsetup(void);
void LCDsetup(void);
void main() {
     PORTSsetup();
     LCDsetup();
     while(1) {
     Lcd_Custom_Out(1,1,"TEST");
}// end main
void PORTSsetup() {
     ADCON1 = 0xFF;
     TRISB = 0x00;
}// end PORTSsetup
void LCDsetup() {
     Lcd_Custom_Config(&PORTB, 7, 5, 4, 3,&PORTB, 1, 0, 2);
     Lcd_Custom_Cmd(LCD_CLEAR);
     Lcd_Custom_Cmd(LCD_CURSOR_OFF);
}// LCDsetup
I just have realized that. Actually in the simulation it works very well now that I interfaced it on actual it doesn't work. The LCD's output is 2 rows of black figures.
Actually ADCON1 = 0x0F would effectively turnoff the A/D on AN12:AN0 or you could set the configuration bit PBADEN = OFF to have RB3:RB0 configured as digital I/O on POR.
The black squares usually indicated a LCD initialization problem. Or I just noticed you do not have a proper contrast control setup for Vee, I would recommend using a 10KΩ Pot with the wiper arm attached to Vee or in a pinch you could use two 5KΩ resistors to bias the Vee. Improper contrast control can result in the appearance of the "black squares."
BigDog
BigDog
How do I read this -> AN12:AN0
I have checked that no problems in that part. Tried both with the POT and without. Still the same output using PORTB in a P18F4620.
So, by turning off the A/D using ADCON1 = 0x0F and turning off the INT would be the solution?
How do I code PBADEN = OFF? I tried ADCON1.PBADEN = 0xFF won't work or just by coding PBADEN = OFF. I'm using mikroC if that helps
AN12:AN0 means analog inputs from AN12 to AN0... these are multiplexed over PORTA and PORTB pins (check the PIN Diagrams in datasheet on page 4).
PBADEN is set during programming. In MikroC go to Project -> Edit Project. Setting "PORTB A/D" to "Disable" will turn of PBADEN.
Also check that you set the correct frequency. If you are using PLL, set freq*4 so that MikroC can calculate proper timings for the display.
You should try setting some LEDs on PORTB instead of LCD and just do a simple flashing loop to make sure the output is working fine (or check with multimeter of you don't have LEDs nearby). If that works fine, concentrate on the the wiring and software.
Reactions: poxkix
    poxkix
Cool. Thanks for that sir bjuric. I found out how to turn it off. By the way, is there another to turn them off by hard coding it?
Frequency you mean for the oscillator?
Okay, I'll try with the LEDs first with the PBADEN turned off
Settings:
OSC_HS_1H
WDT_OFF_2H
LVP_OFF_4L
XINST_OFF_4L
PBADEN_OFF_3H
Revised Code:
void main() {
     PORTSsetup();
     LCDsetup();
     while(1) {
}// end main
void PORTSsetup() {
     ADCON1 = 0xF;
}// end PORTSsetup
void LCDsetup() {
}// LCDsetup
This is commonly because of improper contrast setting.
https://www.edaboard.com/threads/233352/#post996761
https://www.edaboard.com/threads/194246/#post824737
I suggest you connect a 5k or 10k pot, with one leg going to +5V, the other to ground and the wiper to pin 3 of the LCD. Then adjust the pot until you see something on the screen and the squares disappear. If, however, you have all the connections right and this still doesn't give proper display, then it could be for other reasons.
If you wrote ADCON1=0xFF, that should do it. It disables the ADC analogue circuitry on each of the analogue input pins.
You can turn off / disable the analogue circuitry connected to all the analogue inputs by writing
ADCON1=0xFF
You can then turn the ADC off by writing
ADON_bit = 0;
That should be enough. In fact, even if you don't have the ADC turned off (but you probably will have), AN0:AN12 pins will still be digital.
Hope this helps.
Tahmid.
ADCON1=0xFF
ADON_bit = 0;
Hope this helps.
Tahmid.
Please read about my previous post. I stated The contrast issue is out of the question. Whether there is a POT or not it still displays only 2 lines of black figures.
I know my configurations and code are correct because if I transfer it to PORTC it displays perfectly.
So I guessed it is because of the A/D config and interrupt in PORTB. But I prefer to use PORTB since I will not use A/D and interrupts and it makes my circuit more easier of wiring.
I haven't tried the code with PBADEN turned off. So for now it will still be unclear.
So, in your code, add these:
ADCON1 = 0xFF;
ADON_bit = 0;
INTCON = 0;
Set PBADEN off. Turn debug off.
These were all mentioned in previous posts. I'm summarizing it here for you, because right now, I can't think of another reason for it not to work on PORTB if it works on PORTC.
Reactions: poxkix
    poxkix
ADCON1 = 0xFF;
ADON_bit = 0;
INTCON = 0;
Thank you sir Tahmid. I will do this today and I'll post back after I test the curcuit
By the way, what is ADON_bit = 0? I can't get it to work in mikroC
ADON_bit is the bit ADON (bit 0 of ADCON0). If it doesn't work, write
ADCON0.ADON = 0;
or
ADCON0.F0 = 0;
Setting ADON to 0 turns ADC off.
Hope this helps.
Tahmid.
ADCON0.ADON = 0;
or
ADCON0.F0 = 0;
Hope this helps.
Tahmid.
Isn't ADON = 0 the same with ADCON1 = 0x0F?
Thanks for the help everyone. I'm now using the PORTB with the suggested settings.
Actually this is part of interface LCD and keypad connection. I'm taking in part by part so I can eliminate the problems before getting to the next one.
