ZYNQ 7Z030 LVDS IO - 910 Mbps and Ethernet
engr_joni_ee
Advanced Member level 3
I am working with a project having around 70 DDR LVDS 910 Mbps connections to FPGA. I am wondering if ZYNQ 7Z030 have enough LVDS IOs with at least 910 Mbps ?
Another question, as there are two Ethernet Controllers in ZYNQ 7Z030, does this means that no Ethernet controller chip is required on the PCB and only Ethernet PHY port is needed which has to be directly connected to ZYNQ 7Z030 ?
You want to read ds191-XC7Z030-XC7Z045-data-sheet and ug865-Zynq-7000-Pkg-Pinout to answer the question. The larger (676 pin) package has sufficient differential pin pairs, smaller (484 pins) only scarcely.
Yes, only external PHY needed, special ethernet standards might work without PHY.
Yes ZYNQ-7Z030 FFG676 package has the followings.
HR I/O - 100
HP I/O - 150
PS I/O(2) - 128
GTX Transceivers - 4
What is the difference between high resolution and high performance IOs ? Which of them support LVDS signalling ?
The package pinout has an explicit spec of available differential pairs.
Difference between HP and HR is explained in datasheet, both support LVDS at 910 MBPS with respective chip speed grade.
