[SOLVED] Zigbee or CC2500 ??? URGENT
Jigar 4 Electronics
Full Member level 5
Hamilton, ON, Canada
Hi Friends,
My Requirement is a wireless channel (for data transmission) of almost 800m range. at Line of Sight.
I've two option :
1st is Xbee - Pro : https://www.nex-robotics.com/products...e-antenna.html
2nd is CC2500 (Model 3403) : In this option I've two totally different source to buy the product
1) From (Sunrom Technologies) Rs. 1850/- :https://www.sunrom.com/rf-wireless/rf...face-1km-range
2) From Vega Robokit (without antenna) : Rs. 800/- : https://www.vegarobokit.com/index.php...product_id=595
So I am confuse what is there which makes a difference of Rs.1050/- for the same product.
After viewing the datasheet of CC2500 from sunrom technologies (https://www.sunrom.com/files/3403-datasheet.pdf) I come to know that they are providing an antenna.
So my Que. is out of above 3 option what should I use.Which is better to use for me ??? Please Help.
Can I buy CC2500 without antenna(in Rs.800/-) for range 800m (minimum).
Please guide regarding all aspects; I mean regarding the use of the module with ARM7.
Thanks for your time.
Previously posted on RF, Microwave, Antennas and Optics section but needs some more reviews and so I've post it here.
I've 8051 at one transceiver and ARM7 TDMI at the another transceiver.
bigdogguru
Administrator
Southwest, USA
Which ever solution you choose, I would strongly recommend the use of an external high gain antenna for a 800+ meter range.
Also keep in mind the "ranges" quoted in the devices datasheets are for absolutely perfect conditions, outdoors, flat level ground with no trees, vegetation, power lines, buildings, not even as much as a mosquito, etc, between to the endpoints.
Typically, the indoor range drops to a relatively small fraction of quoted outdoor range, case in point:
XTend 900 1W RPSMA - 40 Mile Range
Boasts an ideal outdoor range of 40 miles (64 km), but drops to 3000 ft or 900 m indoors.
Therefore you can expect an actual outdoor range, in typical conditions, somewhere in between the 900m and the 64 km (40 miles).
BigDog
Jigar 4 Electronics
Full Member level 5
Thanks for the replies...
can you tell me how much range I'll get through CC2500 with specified antenna in datasheet ?
Can I get it 100-200 m (Indoor) through this?
horace1
Advanced Member level 5
Norwich, UK
don't know about the cc2500 but I have operated the XBee series 2 over 100 meters (the specification states say 120meters range) and longer distances using routers and coordinators
https://www.digi.com/support/kbase/kbaseresultdetl?id=2213
if used indoors the structure of the building has major effects on range and may need more routers
