[SOLVED] XL4015 5A Step Down Module
DianWardiana
Junior Member level 3
I've used this step down to charge 12 VDC battery. The input is 15-19 VDC and i set output at 13.8 VDC 0.5 Amp.
My question is why i heard sound like "HMMMMMMM" in inductor of this step down?
I'm forget the specification the battery.
Regards,
Ian
There's no reference to a module in your post. Basic XL4015 step down controller doesn't provide constant current regulation, just 7A switch current limiting. Thus I wonder how you are setting current to 0.5 A. What's your input power supply?
Without a schematic, we can only guess about the circuit. I suspect they didn't manage to design stable constant current control.
I've got schematic from this site:
https://cxem.net/pitanie/5-325.php
Here is the schematic:
Regards,
Ian
Not bad at all. According to my trivial knowledge of Cyrillic, 10H could stand for 10 nF?
A problem might be that the current controller PI time constant changes when varying the current set point, not sure if it's unconditionally stable. There should be a series resistance between LM358 inverting input and set point pot.
As what i know from a translate is sure 10H is 10nF.
What do you mean by PI is Power Input? What size of resistor that i must add?
Regards,
Ian
Didn't talk about power input. PI stands for proportional-integral controller. **broken link removed**
I was guessing about a problem. You should first check if the converter is stable in voltage regulation or at higher constant current levels.
If the assumption turns out right, a 1 kOhm series resistor might achieve stability at lower current set points.
The converter is stable in higher constant current levels.
I didn't heard sound like "HMMMMMM" in inductor if i set the output current above 1.7 Amp.
Regards,
Ian
I will try it tomorrow. I will notice about the result.
Thanks for your help.
Regards,
Ian
