Xilinx ISE DCM Mapping Error
u24c02
Advanced Member level 1
HI.
I'm using like following that
Code Verilog - [expand]
8
9
10
11
12
dcm dcm_inst (
    .CLKIN_IN ( fclk),
                  .USER_RST_IN( 1'b0 ),
                  .CLKFX_OUT( ),
                  .CLKIN_IBUFG_OUT(clk_out_0 ),
                  .LOCKED_OUT( lock )
assign reset_n = lock;
always @(posedge clk_out_0, negedge reset_n) begin
 if(reset_n == 1'b0)begin
When i remove 'lock' in that code, Error does not happen,
But i need 'lock' for reset. above code happens error.
error message like following that..
ERROR:LIT:136 - Some of CLK* output pins must be routed if CLKIN pin of DCM
symbol "physical_group_lock/dcm_inst/DCM_INST" is routed.
I don't understand and How am i suppose do that?
