Xilinx custom precision floating point adder
spman
Full Member level 1
I want to generate a floating point adder by Xilinx core generator. My data isn't the standard precision floating point. I want to use a custom precision with 28 bits. But the problem is that the core for custom precision doesn't use dsp slices and is implemented with logic only. The design needs lots of adders and must be implemented with high frequency constraints. What should I do to use dsp slices?
My FPGA is Virtex6 xc6vlx240t.
Thanks in advance
barry
Advanced Member level 7
California, USA
I think the obvious answer is that you should think about converting your custom precision data to a format the core wants, and then convert them back, if you need to.
Reactions: spman
    spman
TrickyDicky
even better, switch to fixed point. And life just gets easier.
Reactions: spman
    spman
