[SOLVED] Xbee pro s2 series is compatible with Xbee pro S2B
rahol
Junior Member level 3
gujarat/india
hello everyone,
i am working on my final yr project , and xbee is part of our communication in our project. we are previously using Xbee pro s2 as a coordinator AT and another as Router , but as one of our xbee is damaged , and now we have buy another xbee that of series S2B , before we are using S2.. but now we are facing problem in communication ...
we are not getting response from router to the coordinator .
plz help me by telling me tht is both S2 and S2B are compatible with each other????
-Regards
Rahul Raghuwanshi
Looking through the manual at **broken link removed** specifically section 10, suggests there are differences between the S2 and S2B. The notable one is the Scan Channels - Set/Read the list of channels to scan (pg 130). It's suggesting a different bit pattern between the versions. I don't know if this will help you, but probably worth checking. Anyway, good luck.
