working with lcd 1602a with atmega8l 16pu
amarsinghkashyap
Newbie level 1
hi I m working with LCD 1602a on atmega8l. i have written a program for displaying some word on lcd. but there is some problem i m facind during compiling my program. There are some error related to undeclared function. can any one help me. Error are shown at the end of program. I m using avr studio 4. and my program is..
#define F_CPU 1000000UL //  1MHz
#define RW PC_4
#define RS PC_3
#define EN PC_5
#define DATA PB
#define ATMEGA8_H
#include <atmega8.h>
#include <inttypes.h>
#include <avr/io.h>
#include <util/delay.h>
void delay(int n); //universal Delay routine for your code; can be customised for your use.
void s_inst(void); //Send Instruction Function Select routine
void s_data(void); //Send Data Select routine
void s_latch(void); // Latch Data/Instruction on LCD Databus.
void main(void) //Main function
int k=0;
char x[4]="HARI"; //you can name it whatever you want.
char y[7]="LAKSHMI"; //You can name it whatever you want.
             RS=0;  //Initialize RS=0 for selecting instruction Send
             RW=0; //Select RW=0 to write Instruction/data on              EN=1; //EN=1 for unlatch. (used at initial condition)
             delay(100000); //some LCDs takes time to initialize at startup
             s_inst(); //Call Instruction Select routine
             DATA=0X38; //Send This instruction on Databus Port 2 on LCD databus.
             s_latch(); //Latch this above instruction 4 times
             s_latch();
             s_latch();
             s_latch();
             DATA=0X0F;// Send Second Instruction on Port 2.
             s_latch();
             DATA=0X10; // Set cursor on line 1. Use 0xC0 to write on line 2.
             s_latch(); //Latch the above instruction 1 time.
             DATA=0X0; //Before changing to write data select. Make port 2 =0x0 so that LCD receives nothing
             s_data(); //Change the input type to Data.(before it was instruction input)
             s_latch();  //Latch the above instruction once.
             for(k=0;k<=4;k++)
                         DATA=x[k];  //It will send x[0]='M' as = 0x4D on Port 2.
                         s_latch(); //Latch the above instruction only once. Or it will clone each character twice if you latch twice.
//to type on line 2 call instruction routine first then send instruction on port 2.
            s_inst(); //Instruction Select routine called
            DATA=0XC0; // Set cursor on line 2. Use 0x10 to write on line 1.
            s_latch();
            //Now it will show Fernandes on line 2.
            for(k=0;k<=6;k++)
                         DATA=y[k];  //It will send y[0]='F' as = 0x45 on Port 2.
             while(1); //infinite loop after completing task
void delay(int n) //Universal delay routine
 int i=0,j=0;
 for(i=0;i<=n;i++)
 for(j=0;j<=10;j++);
void s_inst(void) //Instruction select routine
             RS=0;
             RW=0;
void s_data(void) // Data select routine
            RS=1;
            RW=0;
void s_latch(void) // Latch routine
            EN=1;
            delay(1000);
            EN=0;
            delay(1000);
these error are showing during compiling....................
avr-gcc -mmcu=atmega8 -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT lcd1.o -MF dep/lcd1.o.d -c ../lcd1.c
../lcd1.c:8:21: error: atmega8.h: No such file or directory
../lcd1.c:17: warning: return type of 'main' is not 'int'
../lcd1.c: In function 'main':
../lcd1.c:24: error: 'PC_3' undeclared (first use in this function)
../lcd1.c:24: error: (Each undeclared identifier is reported only once
../lcd1.c:24: error: for each function it appears in.)
../lcd1.c:25: error: 'PC_4' undeclared (first use in this function)
../lcd1.c:26: warning: overflow in implicit constant conversion
../lcd1.c:28: error: 'PB' undeclared (first use in this function)
../lcd1.c: In function 's_inst':
../lcd1.c:73: error: 'PC_3' undeclared (first use in this function)
../lcd1.c:74: error: 'PC_4' undeclared (first use in this function)
../lcd1.c: In function 's_data':
../lcd1.c:78: error: 'PC_3' undeclared (first use in this function)
../lcd1.c:79: error: 'PC_4' undeclared (first use in this function)
../lcd1.c: In function 's_latch':
../lcd1.c:83: error: 'PC_5' undeclared (first use in this function)
make: *** [lcd1.o] Error 1
Build failed with 11 errors and 2 warnings...
Atmega8.h file is not available at proper path, try including in current directory.
The port pins PC_3 etc are not resolved, try writing PC3.
You are using delay.h, it has better routines like _delay_ms() for reliable delays.
Will it be useful if a working c code for same application implementation is available?
