Working of oscillator-with Quartz crystal
pthoppay
Member level 4
Member level 4
working of oscillator
Hi all,
I have attached a colpitt oscillator, which has quartz crystal in the feedback. When i tested the circuit without the crystal it is operating at the required frequency, but when I insert the crystal in the feedback loop it is oscillating.
I would like to know, what might be the possible resons behind this, please help me on this.
Regards,
Prakash.
did you mean when you puts the crystal it does not oscillating
working of a oscillator
yes, when I put the crystal in the feedback path it is not oscillating.
Prakash.
working of an oscillator
Can anyone tell me the function of inductor L10?
thanks
It is used for pulling the resonant frequency of the oscillator.
Prakash.
Are you sure you are not overdriving the xtal?
crystals above 30mhz mostly run in overtone mode
keep this in mind
134mhz direct frequency is hard to achieve from a thin sliver of quartz
maybe reduce the xtal to a sub harmonic
and run in overtone mode is best and most stable
appart form this the transistor needs a load resistor added
or as pointed out youll overdrive it
? what supply voltage are you using ??? 5v dc ??
did you measure dc bias and check its right ???
should be ~ .707v base-emiter
r12 emiter side {between the choke coil and r12
should also have a decoupling cap added to gnd
or the resistor may act as a spring instead and dampen the oscilation}
adding an electrolytic 1uf @10v or 10nf ceramic will help here
and why does L10 have a 0R resistance ????
0R = 0 reactance also
Thanks for the reply.
I am using overtone crystal. I am using a 5th overtone crystal.
For the load resistor I am using 100k.
Supply voltage is 3V.
I removed the inductor in series with the crystal as I dont need to pull the crystal. Hence i named it 0R. I will try using capacitor in parallel with the emitter resistor.
Meanwhile, I didnt undertsand the overdrive concept, can anyone expalin in detail about this concept.
Prakash.
At this frequency you will need about 200-300nH across the crystal terminals to resonate out the 5-7pF of holder capacitance for the crystal to operate as it should. Just make sure the inductor has a SRF higher than the frequency you want to use.
