Wirless embedded network
msadek_eng
I want to make a network of multi embedded board using wirless communication , those boards will communicate with a base station that connected serially to the PC , all what i want is to know an RF tranciever IC that can make this .
This network should connect those station for at least 20 meter spacing
Kind Regards
Abdulsadek
You can do this easily with an access point connected to your pc and with wireless ethernet cards in the number of as you need. This works 2.4 Ghz.
Sir
you are not communiction Eng so if you want to build the unit it consist from 2 parts first one is you embedded system and other one is communiction unit
you don't have to build communiction unit from scratch just and PCI card or PCmica card and see the I/o of it and use it
thanks in advance
before ask any body please ask you uncle first
:D
