jihrenee
Junior Member level 2
I'm using virtuoso to design a wireline transmitter.
There's an instance can be used in analog library --> n4port
The question that i would like to ask is,
in reality how to connect this port?
There are two examples here:
For the left one, the port 2,4 negative terminals are connected to ground, which means RX shares the same ground as TX.
For the right one RX didn't share the same ground as TX.
